Have a good security system installed in the computer
\ plug in the flash drive and the sign will come up scan for virus
click yes and let the security program do the job
If there is nothing important on the flash drive go to the computer right click on the flash drive icon, click on properties and then click on format
that will clean the flash drive and remove the virus
SOURCE: how to remove the lock
First try to see is there any lock in your usb pen drive and see if its not
locking the pen drive, because some pen drives comes with that option to protect
usb ..if its not
Use the Registry Hack to Disable Writing to USB
Drives
Here is the link .just download the zip folder
and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my
level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
SOURCE: to remove virus from pen drive
Open Command.
type the drive name say H:
then type ATTRIB -H -R -S AUTORUN.INF
then type EDIT AUTORUN.INF
then a new window appears, delete all the contents and click on File -> Save and click on File -> Exit
in the command prompt
type ATTRIB +H +R +S AUTORUN.INF
then type EXIT
Remove the pen drive and reinsert it.
The virus is now been deleted.
My mail id is [email protected]
Contact me if you need my help. Thank You
When you plug in your pen drive, don't open the pen drive.
You can see an secondary storage device icon in your 'My Computer'.
Right click the pen drive and scan for viruses.
If you really have virus then the virus, the antivirus agent will show you the virus.
You can kill/delete the virus.
You won't lose any of your data.
( OR)
I have one more option,
If you have linux(Linux Ubuntu, Suse Linux,...) installed in your system, you can login to Linux and
plug in your pen drive, you can delete the virus directly, by opening the pen drive.
Here also you won't lose any of your data.
Cheers...!!!
SOURCE: DVD Player Infected By Virus When Using Pen Drive
I think it is a DVD player with hard disk?
Look for an option to format the disk.
That way you can get rid of the virus.
VIRUS OR TROJAN INFECTIONS:
Virus or trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert thepen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
CORRUPTED FLASH CHIPS ON PEN DRIVE:
If the pen drive is not detected at all, or shows a less capacity, then there are high chances that its a chip corruption. Flash chips are the actual hardware components that save the data. A physical or electrical or electromagnetic damage to these chips make the pen drive faulty. This can happen because of voltage fluctuations and faulty USB ports. In such case, get the flash drive replaced if its under warranty as it can not be fixed otherwise.
FAKE PEN DRIVES:
Sounds a bit un-believable but true. There are a lot of pen drives in the market which are of very cheap quality which are fake copies of some known brands. Beware of such pen-drives. Always purchase pen-drives or memory-cards from a reliable source with bill and warranty to avoid any mess later.
If the pen drive is not detected at all, or shows a less capacity, then there are high chances that its a chipcorruption. Flash chips are the actual hardware components that save the data. A physical or electrical or electromagnetic damage to these chips make the pen drive faulty. This can happen because of voltage fluctuations and faulty USB ports. In such case, get the flash drive replaced if its under warranty as it can not be fixed otherwise.
FAKE PEN DRIVES:
FAKE PEN DRIVES:
FAKE PEN DRIVES:
FAKE PEN DRIVES:
Always take precautions while using pen drives on other computers. See the some of our posts below on protecting your pen drive from viruses:
FAKE PEN DRIVES:
