I can't find the user manual for this particular Whirlpool washer And manuals of a similar model number don't mention the filter location. The customer service phone number at Whirlpool is 1 800 253 1301 and they would want that model number to help. I thought this had a self cleaning filter. Sadly, lint filters may be in quite a variety of locations: https://www.mrappliance.com/blog/2017/march/the-washers-lint-trap-needs-cleaning-too/
Wash your HEPA filter with warm water and allow it to dry if your model specifically states that water cleaning is safe. You can also soak your filter in hot water if it is extremely dirty. Clean non-washable, permanent HEPA filters using a vacuum to remove dust and debris.
make sure oil and filter are clean, coolant is topped up. Check there is no water in the oil. check air filter is clean. check fuel filter is clean. Put some injector cleanrt in the fuel and go for a fat drive
If you find water in the oil and there is overheating have it checked.
To clean the carbureted model's filter, you drain the gas from the tank, remove petcock and filter, clean filter with compressed air, reinstall. The fuel injected model requires that you drain the tank, remove the entire pump assembly from inside the tank, and then replace the filter (it can't be cleaned).
The carbureted model's filter is supposed to be inspected and cleaned every 20k miles. The fuel injected model's filter is supposed to be replaced every 25k miles.
Hello Friend, this is Z. Thank you for allowing me to assist you!
You would need to remove the bucket to locate the filter of your Frigidaire dehumidifier (FDL70S1). Then pull the filter downwards for cleaning. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions and typically the FILTER REST light will illuminate after 250 hours of operation. Hope this helps!
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
