SOURCE: PNY USB Flash Drive
Perhaps you have some outdated drivers.
May I suggest, VersionTracker Pro $29.95
http://www.versiontracker.com/windows/
Keeping your software and drivers current helps keep your PC running smoothly, but locating and matching the right updates for your machine can be frustrating and time-consuming. With VersionTracker Pro, you don't need an IT department. VersionTracker Pro scans your hardware AND software to determine the right updates for your drivers and applications.
SOURCE: V3m can't save picture
tom2209 - you try resetting the entire mobile to see if that corrects the errors.
Guest, - you can install the software that came with the phone.
SOURCE: Hi, we are a 501c3
Unfortunately I do not have any good news for you ...If the image do not appears anymore..it means that it either has a power issue..or the lcd screen is gone bad...and need to be replaced..and in this case I don't think is worth the trouble ...cause it may cost more to buy the screen and replace than buying a new one ...The only thing that you can try is to see if the problem is not from the ac adapter charger...Being the only power source on this frame ...if the charger is burned..it can cause the frame not to work anymore...so ...try to locate a charger with the same kinda plug ..and on the same specifications regarding the voltage ...and try to see if plugging a new one makes it work again ...If it does...you are lucky ...but in any other case it is not worth repairing unless it has a sentimental value and you want to do it regardless of costs..
In short ...being used for a long period of time ..there is possible that the ac adapter to be burned ..and replacing it ..can be a chance for making it working again ...but pay attention to be the same voltage as on the original one...otherwise..the repairing can not be done due to high costs and lack of replacement parts..
Good Luck ...!
You have to watch out when buying storage cards, a lot of fake cards are being sold and it says on the card 32gb but sometimes they only have 8 or 16gb
