Refrigerators Logo
Jerry Woodard Posted on Oct 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Highest temperature for Oneida 31161 digital thermometer
Paul Bade
Level 3:
  • Refrigerators Master 1,818 Answers
  • Posted on Oct 18, 2017
Paul Bade
Level 3:
Answers
1818
Questions
Helped
574396
Points
5816
The best information I could find was that the absolute maximum is 392 F (200 C). Exceeding this temperature will likely ruin the temperature probe.
1 Related Answer
Anonymous
  • 35 Answers
  • Posted on Jan 02, 2010
SOURCE: freezer and refrigerator run about 8 to 10 degrees
check freezer coil for ice, then defrost timer and then fan and switch fan
I have a oneida thermometer and my probe is not working can I buy a replacement?
FIXYA IS NOT A RETIL OUTLET NOR DO WE KNOW WHO SELLS THEM
Jul 16, 2021 • Grilling
How to change the Celsius to Fahrenheit on the Oneida Probe thermometer
Hi Carolyn,
press the refrigerator key and freezer key together for 5 seconds. It should toggle between them.
Sep 18, 2019 • Home
What does Lo mean on a digital thermometer?
The sensor is sensing a temperature that is lower than the lowest possible temperature that can be displayed on the thermometer. If it is actually warm then the sensor has failed
I lost the instruction manual to our Oneida digital meat thermometer
The buttons should tell you what to do, they are all made be same people just take a few minutes to play with it. Normally set temp you want, or set time you want, pretty easy
Mar 23, 2014 • Cameras
1helpful
Kenmore 700 series dryer little temperature difference between delicate and high
Using that thermometer I am guessing that the readings are close to what they should be. Typically there is not as big a temperature change between the two settings. What made her first think there was a big problem in the temperature settings?
Sick dog
How to take Dogs temperature?
Required Things:
• Digital pet thermometer
• Lubrication, such as petroleum jelly or mineral oil
• Soap and water
• Rubbing alcohol
For a breeder it is mandatory to know why their pet not feeling well? Why he/she has lack of appetite, restless, and not involved in daily activities. These are signs and symptoms suggested that their pet is ill. Fever can be in these illnesses. It requires special attention. A dog is not express like human when it gets fever, and has not signs (e.g. warm skin, and trembling). For these reasons it is important to know and learn how to take temperatures reading of fever as a vet can do it. It can be done very impressively to follow the following steps:
First of all you should have a Digital pet thermometer; it can be bought by local market.
For your help call somebody who hold the dog when you take the readings.
Do clean your Digital pet thermometer with prescribed rubbing alcohol.
Before taking a temperature apply lubricant (i.e. petroleum jelly or mineral oil).
Pick dog\'s tail upward and insert thermometer gently into your dog\'s rectum. Put it into half of the length of the thermometer.
Grasp the thermometer in that position until it beeps, or for 1 to 2 minutes.
Pull it out and look at it to see what your dog\'s temperature is.
The normal body temperature should between 100.5 to 102.5 degrees Fahrenheit
Clean the thermometer thoroughly with semi-hot water and prescribed soap
Ask your vet if temperature is low or high with sign of sickness.
During the learning process (dog\'s temperature measurement process), be relaxed and don\'t show nervousness to your canine. This will add to the pet\'s irritation.
Be very conscious during all the process of taking temperature, don\'t insert thermometer into deep of dog\'s rectum, it can be a cause of pain.
Tie a cord around the other end of the thermometer so that if it slips or accidentally go into your dog\'s rectum too deeply, you will be able to easily pull it back.
Remember a digital pet thermometer is best than an oral human thermometer to measure dog\'s temperature. Conventional sort (contains mercury) can be very dangerous if accidentally broken.
Always prefer rectal digital thermometer to take a temperature reading of pet.
Ear thermometer is also available in market but it is not as accurate as rectal thermometer is.
Never strive to take your canine\'s temperature if he/she is very irritated or very hyper. If you do so, it could be dangerous for pet. Be patience until dog calms down when he/she calm down then attempt to insert the thermometer.
Without lubrication insertion may be dangerous action it can cause the pain.
Self medication is prohibited if the temperature of pet is very low/high.
Do not get anger with your canine if he/she will not get calm enough to permit you to insert the thermometer. Take him/her to your vet if you are not capable to take your dog\'s temperature.
FOR MORE READING ABOUT A SICK DOG SIGN AND SYMPTOMS PLEASE VISIT
http://www.dogbreedplus.com/dog_care/how_to_take_dogs_temperature.htm
FOR other information visit.....
Jan 11, 2013 • Dogs
Oneida thermometer manual
The thermo temp says low but everything else is fine. I changed the batteries 3x. What should I do?
I have a used Tappan gas range with 4 burners and a griddle in between the burners. everything works, but the oven temp varies about 40 degrees above and below the setpoint. it never seems to level out...
not normal
problem thermostat not lighting the gas or turning the gas off to maintain an even temp
temp variation should be around a 10 degree range
call a gas fitter to check out the oven controls , thermostat or thermocouple
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
