SOURCE: wont show Removable disk
ok
try to plug it to other ports.
change your data cable/ usb cable then plug it in.
restart your computer.
pls rate me up if this would help
SOURCE: i cant use any flash drive on my pc
If you are using XP and don't have Service Pack 2 intalled then try to install Service Pack 2.
SOURCE: Won't scan credit card
You didn't indicate what you are attempting to scan to, but the scanner won't just "scan" the card, it will send the data it reads to an application that is monitoring the connection from the scanner.
Verify that the scanner drivers have loaded properly and then make sure that the capture application is running and looking for the scanner connection.
