You should initially visit the application store on your keen TV
Add the Amazon Prime application to your Channel via looking for the equivalent
When you have effectively included the application, dispatch the equivalent
You should then tap the Registration choice in the wake of finding it
You would now be able to discover the check code springing up on your TV screen
Duplicate or make a note of this code and visit www.amazon.com/mytv enter code on a web program application
Sign in to your Amazon account utilizing your login qualifications, for example, your Username and Password
Enter the remarkable enactment code that you recovered from the TV screen
Register your gadget by affirming the actuation code
Following the means above will finish the actuation cycle. Be that as it may, you might be approached to choose the TV link specialist organization. In such cases, you have to peruse through the given alternative and sign into your record. What's more, that is it, you are finished.
If you are facing any difficulties using Amazon Prime simply visit www.amazon.com/mytv. Their Amazon expert team 24*7 available for customer service to resolve issues and provide a perfect solution by on call.
More info:- https://sites.google.com/view/www-amazon-com-mytv-enter-code/
You need to use the Amazon start page on your TV. It will probably give you a new code. Go to your computer Amazon.com/activate
you should be able to enter the six letter code to start your subscription. You should have Amazon Prime to use this feature on your TV.
SOURCE: unable to change v-chip code in my sharp television set HELP
Go to Sharp webste http://www.sharpusa.com/ download your manual for the tv and whala it is done...
Need to get ahold of Amazon for this issue.
