I Have a Neff 1451 Oven. The oven part is not heating up.
The fan is fine, the bottom heat plate heats up, the light goes on, the thermostat clicks and the timer is visible and set.
I bought a new element and replaced that but no heat. The TOC conducts so I presume its fine.
The top grill doesn't heat up either.
I have 3 oven element wires available to the element all white with 2 red flecked and 1 black, when I took the element out there was only 1 red and 1 black connected, did the other white/red label fall off which seems to be next in line to the TOC? Im worried about connecting it all back up.
Re: Neff 1541 not heating with replacement element
Yes two red flecked on same terminal and the black flecked on the other side terminal of the element. Bobs your Uncle......HEAT! Make sure they are a tight fit. New spades if required.
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
For all Free appliance repair videos visit our VIDEOTUTORIALSneff video 1, If the fan motorin the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter. To gain access to the NEFFelement you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the elementyou willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the elementis open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine. 2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motoris working you willsee the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven thenyou need To replace the oven fan motoris a little moreexpensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat 4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timerinto AUTO mode,simply put oven back to MANUAL mode and all should be working again.
TUTORIALS1, If the Neff fan motorin the back of the oven is going round and
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Please rate my solution.
Thanks.
TUTORIALS 1, If the Neff fan motorin the back of the oven is going round and
breakers off ,,,back wall bottom center is a mounting plate 2 screws to take out the pull out wires and remove wires(careful not to let them slide back in)install new element...wires first the push back in place(no need to open back) don't forget breakers on now...you did it.... good for you.
Neff fan oven element video.1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter. To gain access to the NEFFelement .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the elementis open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine. 2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motoris working you will see the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven then you need To replace the oven fan motoris a little more expensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat 4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timerinto AUTO mode, simply put oven back to MANUAL mode and all should be working again. For all Free appliance repair videos visit our VIDEO TUTORIALS
