Dishwashers Logo
R
Richard Weisfield Posted on Oct 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a Miele G 870 SC dishwasher. The soap dispenser always opens properly to dispense soap if we run the Economy cycle, but it always stays closed if we run a Normal or Intensive cycle.
Soap dispenser was replaced recently. Could this be a fault in the control timer, only triggering the dispenser relay when the timer starts up in Economy? In the other cycles, there does not appear to be any dishwasher activity during the Main Wash portion of the cycle.
Rene Williams
Level 2:
Habit-Forming:
  • Expert 93 Answers
  • Posted on Oct 02, 2017
Rene Williams
Expert
Level 2:
Habit-Forming:
Answers
93
Questions
Helped
27582
Points
267
I would certainly check with the repairman and have it checked. It is possible that a connection may have been missed since the new dispenser was installed.
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Feb 16, 2008
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Anonymous
  • 525 Answers
  • Posted on Jun 04, 2008
SOURCE: soap dispenser
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Anonymous
  • Posted on Dec 13, 2008
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Anonymous
  • 187 Answers
  • Posted on Apr 14, 2009
SOURCE: soap dispenser does not open during wash cycle
  • Hi,
    please try this...
    imer:
            On mechanical set ups the timer is attached to the detergent cup by an actuator arm. This arm is usually plastic, and if it is broken or otherwise defective then the detergent cup wont be opened. Check the linkage to make sure it is functioning correctly.
    Bi-metal switch or wax motor:
            The bi-metal switch is simply a very precise device that warps, bends, or otherwise deforms when power is supplied to it. The timer operates the bi-metal switch, which inside the dishwasher door. Then the switch is supplied with power and it is working properly, the bi-metal switch deforms away from the latch holding the detergent cup closed and the cup opens dumping the detergent into the washer.
            Some dishwashers have this switch wired through the motor power feed or the heating element. If they are defective then the detergent door will not operate correctly. If the switch itself is defective then you will need to replace it. Another type of mechanism is a wax motor. Wax motors are sealed units filled with wax and found in newer dishwashers and work by heating the wax and forcing up a piston which in turn mechanically opens the detergent cup door. This type of device is also controlled by the timer.
    Detergent cup:
            Sometimes the detergent cup becomes built up with old detergent that prevents it from opening correctly. It's usually a simple fix to clean this out. If cleaning it is impossible then you may need to replace the cup assembly.
    please rate my suggestion..
Anonymous
  • Posted on Jun 07, 2009
SOURCE: Dishwasher soap dispenser sticks
Your soap is clotting because there isn't enough water being sprayed around inside.  The water spray washes the soap out of the dish, if all is working well.  My machine had the same problem.  I had sufficient water level, but the spray head wasn't spinning very well.  I found the end-most hole in the spray bar to be plugged.  It is the end hole that provides a jet that makes the head spin.  I cleaned a bunch of debris out of the hole and the mchine started working and cleaning like it was new.  That was quite an axccomplishment since the machine is 15 years old.
Will a Miele G575 Soap/rinse aid dispenser fit and work in a G664 dishwasher
The Soap/rinse aid dispenser of a Miele G575 is not compatible to be used in a G664 dishwasher. It is important to note that the dispenser is model-specific and not interchangeable between different models of Miele dishwashers. It is recommended to check the manual of your G664 dishwasher or contact Miele customer support to make sure you get the correct dispenser for your appliance.
Miele dishwasher G664 - door to cleaner dispenser doesn't open
Could be soap buildup in the dispenser or on the door hinges. Try running leaving the dispenser door open and run a wash only cycle. It may wash out any soap buildup.
1helpful
2answers
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 • Dishwashers
1helpful
Miele dishwasher G 1232 sc no longer dries
the problem with not drying is normally three things
1. not adding enough rinse aid to the compartment (dispenser) and adding to much soap.
ex rinse aid helps with drying,spots and cleanind the dishes. so if is none then you want get maximum cleaning.
3. make sure you run the faucet to get the hottest waster going into the machine this will make the other two do it job better because as you know you cant clean dishes properly in cold water.if this info helped please send me 4 thumbs post , thanks
Mar 01, 2010 • Dishwashers
1helpful
The soap dispenser door does not always open
the dispenser has to be changed. there is a spring that might not be spring back to open . its easier to replace then to get the kit and rebuild your dispenser.
Feb 24, 2010 • Dishwashers
Dishwasher does not rinse clean
run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Apr 22, 2009 • Dishwashers
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
10helpful
Oct 26, 2007 • Dishwashers
Top Miele Dishwashers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
