SOURCE: tuning in the tv
Most TV's auto search feature will try both the Cable and the Air
frequencies, but perhaps yours doesn't. Go to the menu page for
tuner setup and make sure it is set on Air (might be called broadcast)
and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
SOURCE: unable to view digitial tv pictures but audio and analogue pictures work
If you have cable and a top of set box , it may be the problem. If you hook the cable direct to the set and still no digital ... then the TV could have a defective digital board. The tuner is on this board and the tuner gets both analog and digital signals.
SOURCE: I have just purchased a
After some searching I found that I needed to assign the digital input, as instructed on page 30 of the instruction manual, "The Input Assign Menu".
SOURCE: daewoo lcd dlt 20w2
Hi this is warjis ahmed,
I can solve your problem of DLT-20W2
My email> [email protected]
SOURCE: Lost all digital channels - Sony KDL-52W3100
Use ur original remote of the tv u want setup to the DTV box go menu switch cable back to air
reseption.Set tv channel 3 hook up the DTV box and rescan the channels u have it.
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers,
for spare parts and service and
Installation Instructions
as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
