K need to know if it's digital I need to know if it needs an antenna need to know how to program it really
It should have inputs for analog AND digital.
http://thebooksout.com/downloads/proview-rx-326-user-manual.pdf
This site seems to have it, but might be a charge.
SOURCE: Can't program digital channels only has analog option
If your TV does not have a digital tuner, you'll need a digital converter box.
After the digital switch in June, did you have channels then? If so just do a rescan.
SOURCE: I live in Canada and subscribe to Shaw cable
There may not be a code set compatible with your Proview TV since this brand is not that widely distributed.
The code sets available in any remote reflect the brand names and feature sets of TVs (and other entertainment electronics) that prevailed when the remote was designed.
Even the so-called 'learning' remotes will not program to every InfraRed remote.
Your best chance is to check Shaw's website for the most recent codes:
Shaw User Guides
SOURCE: Hi, My Proview RX326
That usually means a bad backlight inverter or t-con. Do you have a dull glow on the screen?
