It's okay to install shower pan without cement under the pan. According to chriply.com, if you want to get maximum strength and weight holding capability then you can put cement or sand under the pan.
This video doesn't show needing cement -
Maax Professional Installation Video KDS Series
SOURCE: i bought a maax shower
There are two ways that I would do it depending on the width of the ledge on top of shower base. If you have enouch room I would shim studs with strips of material thick enough to bring the surface out even with flange on shower base. Then I would put cement board(wonder board) on wall and over shower flange to set on top of shower base. Finish seams on wall board per manufacturers directions,Let seam filler dry then seal with thompsons water seal or equivalent sealer. Let that dry then tile on that grouting and sealing with quality caulk at joint between shower base and tile.
If ledge on shower base is not wide enough then I would place cement board directly to studs then use filler strips on face of shower base flange to bring two surfaces flush. Water seal let dry and tile again coming down over top of shower. Grout and caulk to finish. P.S. I would use a siliconized latex emulsifier to mix in with grout. It gives a better ware proof seal. Hope this helps you. Good luck and thank you.
SOURCE: I need to remove the Maax shower base and can not
Hello, You shouldn't have to resort to that extreme. The drain unit that the retainer sits in is the part securing the base down, have a look at the diagram in this link: http://www.maax.com/Upload/docs/premium/technical/en/000_10014442_0904-2_E.pdf
The drain assembly should unthread and release the base. But sometimes they tend to work as designed.
The retainer is a compression fit (or should be... do you know the installer? they may have deviated from the described installation). Assuming a proper install, use a flat-head screwdriver and a utility knife to seperate the inside portion of the rubber seal of the retainer, from the plastic ring. The ring should now be able to be pried out, and the drain portion unthreaded.
If this helped, please rate a four-thumbs up. Thank You.
SOURCE: Where can I find shower
amazon is one of the best places for purchasing your shower door rollers. Click here Amazon com shower door rollers and choose the best one (many of them are compatible with maax shower door), but anyway, before order something contact the seller to be sure. There's a plenty of rollers, so take a look.
I hope this was helpful.
enjoy
