SOURCE: I'm looking for a factory manual for a Beeman air
Contact Beeman via one of the methods available at the following link:
http://www.beeman.com/contactus.htm
and let them know what you're looking for. Most all gun manufacturers will provide a free manual for anything they've manufactured. It's a safety thing.
Take care!
SOURCE: beeman air rifle wont latch when cocking
you have a triger fault its not locking the piston back best and safest bet is a gun smith,, never play with a triger if your not good with guns,
SOURCE: I have a beeman rs1 chinease air rifle is the
Yes they are adjustable, both 1st and 2nd stage and also trigger weight.
The trigger group is easily disassebled and honed with fine emery paper. You really dont need a mirror surface but the factory surface is very far from smooth. There are som sharp corners on the sear and the trigger lever, DO NOT ROUND THEM.
Pay close attention to the three small springs inside, if you get them mixed up the rifle will not lock.
This work will make all the difference in your rifle.
Just work slowly and with caution not to change the angles in the trigger geometry, all you want to do is polish the surface.
Tutorial can be found here http://webpages.charter.net/guru1/documents/RSE%20Airguns%20-%20Beeman%20RS2%20trigger%20guide.pdf
SOURCE: What is the best cleaning technics, how often,what
Go to http://www.network54.com/Forum/79537/.
You can learn a lot there.
