SOURCE: Vegtables freezing in refrigerator drawer
This could be due to frozen air passages...defrost the unit, food packed too close to the passages, possibly low on gas. First, clean out your condenser radiator at the bottom of the unit...rear. It is probably blocked.
SOURCE: Food in Chef's Pantry drawer freezes, even on warmest setting
check the cold control or the door is not closing proper
SOURCE: deli drawer freezing food
The temperature in the section or the refrigerator isn't set correctly.
Also, check the thermostats if it is functioning correctly. PLEZE LET ME KNOW.
SOURCE: my Kitchenaid refrigerator deli drawer freezes everything, how can I fix this?
Check the air flow vents for ice buildup, this happened with my whirlpool fridge. Hope it helps.
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
