SOURCE: DeLonghi 50 Pint dehumidifier DE 500P won't turn back on
If it is not responding when you try to activate the shutoff button and are still not recieving an acknowledgement that the bucket is full you may hav a defective shutoff button. Try contacting the Manufacturer and see if you can purchase just the button. This i a common part and the price is usually reasonable. If you feel very technical inclined you can remove the button and touch the 2 wires together simulating a closed contact. The dehumidifier should now acknowledge the bucket is full. If you recieve the notification then the button is bad. If you found this solution helpful please rate it.
Thanks - Tech101
SOURCE: kenmore dehumidifier is running but not pulling water
normally this means that the compressor is not running. Check capacitor and connections to compressor.
David
SOURCE: Power lose
I had the same problem with my 50 pint unit. The bucket full light flashed, would unplug, restart, filter clean it, etc. It would not fill up with water. I finally checked the coils. The coils were filthy after 18 mos of use and needed to be scrubbed clean with a toothbrush. There are two sets of coils on the 50 pint. Check and clean both. My unit runs as new now.
SOURCE: dehumidifier fails to start.
it should be a float whitch..somewhere around that bucket....take a look, sounds like it stuck ..and tripping whole system
SOURCE: dehumidifier is saying bucket is full but it is empty
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Here
is a tip that explains what can be happening to make the dehumidifier
show that the bucket is full when it is not.
Dehumidifier
heatman101
