SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
SOURCE: how to thread sewing machine
Yes, but it is a good basic machine.
Here's how to thread it:
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
all machines thread the same. TTN tension, take up,
needle.
Beginning with the spool, guide the
thread through the thread guides to the tension assembly. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way.( If you load your bobbin
case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
There are some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
SOURCE: I just got a used juki ddl-5550-6 sewing machine.
PLEASE CHECK FIREST TIMMING BETWEEN NEEDLE AND HOOK
OR GO TO WWW.JUKI.COM U WILL FOUND USER GUID ALL LOCKSTICH MACHINE SAME ADJUSTMENT WITH DDL SERIES
BEST REGARDS
SOURCE: How to thread bicor vx 1005 sewing machine?
Most older machines start the thread from the spool on a spool holder then the thread goes through a tension dial, on to another tension holder inside the case. Then make sure the thread is going through a lever that goes up and down with the needle, through a thread holder near the needle.
SOURCE: Manual for older kenmore sewing machine
Manual Here: http://www.managemylife.com/mmh/lis_pdf/OWNM/1006108L.pdf
