Hey what was your fix? I am having the same issue. There is no option to change to uppercase
Hi Glenn,
Depending on the version you have , there is either a key labelled "upper" or there is a button with a "123" on it that cycles modes from letter to numbers to upper case to lower case etc or I have been told there is a button labled "!@#" which apparently does the same thing.
SOURCE: Lg Ke970
when u get a text sheet... press the # botten twise and then once.. then start typing...
SOURCE: Changing to capital letters in texts.
i might be wrong on this one, but all motorola's are mostly the same on texting. Soto get a capital letter in text just press the 0 before the letter
SOURCE: How to type in capital letters on facit typewriter?
You did not specify if it was a manual or electric or the model, so assuming it is a standard manual or electric machine, push down on the shift key and hold it, then type your letter or letters. If you are typing everything in caps, press the shift lock key.
SOURCE: My Lenovo3000 V100 h6as th6is strange fault. When
it is the problem of your keyboard keys connection because one or more wrong letters are typed
SOURCE: When typing on my wirless keyboard it reglarly
Hi
I have the same keyboard and mouse that I got new with the computer. Shortly after it arrived my keyboard started adding characters. HP sent me a new keyboard and all has been fine.
Hi Glenn Anderson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
NOT TV MODEL TOLD AND IS NOT A COMPUTER SO I MOVED YOU, OK>?
YES WIFI SETTINGS ARE CASE SENSATIVE
AND YOUR NOT TOLD TV MODELS MANUAL COVERS ALL THAT.
NO TV TOLD MODEL. AT ALL. SO CAN NOT READ THE BOOK TO YOU.
