My luminous inverter is showing overload 850va
SOURCE: inverter keeps showing overload red led when its
if there is no short circuit any were then the overload control may be bad
SOURCE: why would my new 1500 watt inverter readout show
It would show overload if you're drawing more power than it can supply. 1500 Watts is a very high output for an inverter but that is the maximum it's capable of. As with any electrical supply you should not draw the maximum power it's capable of as this can cause it to burn out. Around 1200 would be the max you should draw continuously. You need to check the power requirements of whatever you're running on it. Also you need to check that it's capable of taking 13.8 volts. If 12 volts is the recommended input, putting in 13.8 will increase the voltage output which could damage appliances being run on it.
SOURCE: I have sukam inverter 1500va, when I put it on it shows overload without any load
internal problem
have it checked out by an accredited service repairer
