Thermostat might be stuck. My fridge stopped working recently and I hit the thermostat control a sharp blow with the handle of a soft-handled screwdriver and it started to work again.
I had to hit it several times over the next few days to keep it going until the new thermostat arrived but since it was delivered the fridge has been working normally...
SOURCE: Kenmore Trio 596.75509400
My problem is identical to jcalhoun on Sep 21, 2008..I have a Kenmore Trio 596.75502400. Freezer is ok..Lights are on. Any help would be appreciated.
SOURCE: Amana bottom drawer fridge/freezer combo
hi. thanks for the question . it sounds like you have a compressor problem . wich is under warranty from amana. great news get in touch with amana thanks the appliance doc
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
SOURCE: Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
SOURCE: Fridge unit was cooling poorly
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
