If the second hand of your watch isn't moving, but the watch is otherwise keeping time, you most likely have one of two problems. The simpler to fix problem is that the second hand might have come loose from the post onto which it's been fitted. It's a simple friction fit, and a watch technician would simply remove the watch movement from the case and very (very!) gently push down on the seconds hand to re-seat it. If that's the problem, that's all there is to the repair.
A second potential cause for this behavior could be that a speck of dust or crud has gotten into the gears that operate the seconds hand, preventing it from moving. This can easily happen when changing a battery--many watches tend to get somewhat of a buildup of crud where the watch back meets the case. Especially with screw back cases, the process of loosening the back also loosens the crud layer, making it easy for little bits to fall in. If you do have crud in your movement, you're a bit limited in what you can do. Unlike old-time mechanical movements, very few quartz movements are made to be disassembled and cleaned. Instead, a watch repairer may be able to blow some air (not compressed air from a can--that will probably wreck your movement) to try to clear the gears. If that doesn't work, there is a little device that some watchmakers have that runs your watch at about 50 time as fast as normal. Spinning the gears like that can sometimes generate enough force to clear a blocked gear train. I have done this to resurrect several watches whose hands were stuck. However, I was still able to see the "pulse" of the second hand on those watches, even if the hand itself never moved forward.
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Use a paper clip/small knife to prise the steel cylinder out from the side (go in from the back), it takes a bit of pressure but dont be scared. Once its popped out a bit you can turn it to adjust time
