Pour penetrating oil down the upper shaft if possible. Remove the allen scews from the base with 5/32 T handle wrench. Remove the round snap ring on the motor shaft. Use vise grips or channel lock to secure the shaft. Twist the blade off and inspect it. It most likely will need to be replaced as the key that slides on the shaft will have deteriorated.
You will need to find a "small appliance repair shop" in your area, most likely the main PCB has failed, it controls the motor. Check the yellow pages.
There is a reed swich (safety switch) located on the top where the lid comes down. A reed switch works with a magnet. If the magnet is missing or the reed swictch is bad, no power will be allowed to the motor. Send me your e-mail & I will look up the part # in my Robot-Coupe manual. [email protected]
Remove the base the screws are under the rubber feet,on top of the machine there are three screw caps remove these with a bradel, unscrew screws with large torx screw driver, remove spindle anti clockwise by locking out fan at base. for all Robot coupe parts go to http://www.catering-machines.com/
That plastic piece is a sling disk or sling blade and made to sling product to the discharge chute. Believe it or not, the motor shafts wear out and could be the cause of premature failure. When you install the new sling blade, check to see how much slop/ play there is by moving this back and forth on the shaft, a small amount is ok (1/16th to 3/32nds). The other thing to look at is forcing or overfeeding the unit. You can contact them at Robot-coupeusa.com
