Question about Kenmore Washing Machines
I have a top load Kenmore washer. When I push start button the lid locks and senser light comes on and makes a noise like it is starting, then the senser light goes off and the lid unlocks.
    Top Expert:
  • Kenmore Master
  • 6,289 Answers
Is the lid actually locking when lock light comes on? If not, replace lid lock
Posted on Aug 26, 2017
  • 3 more comments
  • Dana Engh
    Dana Engh Sep 10, 2017
    This is what's happening with mine too, lid locks then unlocks right away then nothing
  • Chris Huff
    Chris Huff Sep 10, 2017
    If it's a top load model, most likely the mode shift actuator is bad.
  • Chris Huff
    I would check drain Pump first though to be sure it is working and unobstructed.
  • Chette Nichols Jr
    Chette Nichols Jr Sep 10, 2017
    Could be the timer/load switch needs replacing.
  • Chris Huff
    Most likely mode shifter actuator if Pump is ok and unobstructed
6ya staff
SOURCE:
Anonymous
  • 13 Answers
SOURCE: Whirlpool Duet Front Loading Washer Won't Turn On
mains filter blown door lock fail main pcd fail appliance doctor
Posted on Feb 02, 2007
Dov Dror
  • 641 Answers
SOURCE: Kenmore Model 27032 lid problems
Look for the lid switch and press on it manually. Let me know if it will operate the machine.
Posted on Sep 12, 2007
Anonymous
  • 14 Answers
SOURCE: Washer comes on and it makes a humming noise
is the motor running?? maybe its stuck....
Posted on Jan 14, 2009
Anonymous
  • 1066 Answers
SOURCE: kenmore top load washer making loud noise in spin
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Posted on Apr 03, 2009
machinetech7
Jason Kennidy
  • 1344 Answers
SOURCE: Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Jun 02, 2012
Kenmore 11025102310 washer isnt working. I press the start button, and the sensing button lights up for just a second and there is a couple of minutes of a grinding type of noise but then nothing.
SENSING Page 5
When the START/PAUSE/Unlock Lid is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will use short, slow spins to estimate the load size. These sensing spins may take 2 to 3 minutes before water is added to the load and you may hear the hum of these spins. If the sensing light is on, then washer is working properly. You will hear the motor turn the basket in short pulses to thoroughly wet the load. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: Avoid opening the lid during sensing. The sensing process will start over when the washer is restarted. The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
If there's no water, then Page 13
Washer won't run or fill, washer stops working, or wash light remains on (indicating that the washer was unable to fill appropriately)
Check for proper water supply.
Both hoses must be attached and have water flowing to
inlet valve.
Both hot and cold water faucets must be turned on.
Check that inlet valve screens have not become clogged.
Check for any kinks in inlet hoses, which can restrict water flow.
Or you have an inlet valve that is not working
Apr 29, 2016 | Kenmore Washing Machines
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Lights come on but nothing happens when I hit the start button?
Hi just read your posting.Now just a couple of questions.When you push the start button does it make a beep noise?Do the other buttons work?Have you tried advancing the cycle to spin and pushing the start button?This problem could be a faulty display board or faulty lid switch,or water valves.Please reply with additional information on the questions and I am sure we can rectify this fault.Does your machine have a lid lock light and an Efficiency option button.Looking forward to your reply.
Jun 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
Power comes on and all lights come on, but the washer will not start the wash cycle. After the start button is pushed the lid lock will not lock.
That is why the washer won't start. Replace the lid lock. It is there to stop anyone from putting their hands inside of washer when it ia agitating, by stopping power to the motor.DO NOT try ANY attempts to mmake it work!!!! Injury may result
Feb 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 70 series
I am assuming there is no noise coming from the machine, if not check the lid switch. open the lid and look for a small slot in the top of the washer. With the washer set to run, press down on the slot with a screwdriver or something (make sure everything is clear from the tub) see if there is a clicking sound when you push down. If the machine starts you need a depressor piece on the door. if there is no clicking sound you may need something else. lets start with the simplest, like the door switch and go from there.
Nov 02, 2007 | Kenmore 22422 Top Load Washer
Error - LiD
Probably something wrong with the lid lock system. You should here a good sized click and the lid lock light should come on. If not, its probably a bad lock system. Good Luck!!!! Jim
Sep 03, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
351 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
