In this article we have defined the issues with your mobility scooter Beep codes are diagnosis Find the issue of your Pride Go Go mobility scooter here
The Drive Scout 4 electric scooter beeps seven times when trying to make it go because it indicates a throttle control issue. The seven beeps signify that the throttle control is not in the neutral position. This can happen due to a faulty throttle potentiometer or a loose connection between the throttle and the controller.
It is good to know that you have already tested the potentiometers and replaced them with new parts. However, if the issue persists, you may want to check the wiring harness for any loose connections or damage. A damaged wiring harness can cause intermittent problems with the throttle control, resulting in the seven-beep error code.
Another possible cause of this issue could be a faulty controller. If all other components work correctly, but the scooter still beeps seven times, it may be time to replace the controller.
In summary, the Drive Scout 4 electric scooter beeps seven times when trying to make it go due to a throttle control issue caused by a faulty potentiometer, a loose connection, a damaged wiring harness, or a faulty controller.
What is the brand of scooter? I had a similar problem and the solution was contact the support, they give me some brief instructions by phone and the beeps was out.
you may have got some of the electrics wet, if so it should dry and be fine, if not then we need to know how many light segments are lit, and how many flashes.
