SOURCE: No power to my Hitachi 42hdm12
Hi, If even trying the TV in another known good outlet, it still doesn't work, do a hard/full reset - turned off via master power or unplug for a couple of hours. If all else fails, maybe you should seek the services of a qualified professional since this involves opening the unit, circuitry diagnosing and board/component repair/replacement. Hope this be of some help/idea.Post back how things are or should you need further information. Good luck and kind regards.
SOURCE: Hitachi 50UX14B rear projection: Took apart 2 clean, now red is off
What do you mean by covers? do you mean focual lens? did you replace them to there proper place (red to red, green to green, ect..). each has it's own focal legnth and must be placed on the correct gun. did you adjust (accidentaly) the red centering polls?if you did please have a tech readjust them you can end up with convergance amp overload. did you try to converge the lines? if they did not move when adjusting you may have a convergance amp problem. read my motto
SOURCE: tv won't turn on either manually or with remote
THE RCA TV WILL NOT COME ON ,BUT THERE IS A LITTLE HUMMING SOUND
SOURCE: Have a Hitachi 55hdt79...no pictures only sounds.
It might be the power supply, check the main power supply. Audio power supply is seperate to main power supply, thats why you have a sound.
