SOURCE: I need a manual for my Apple Ipad Wifi 3g
Apple provides manuals for all their products online...hope this helps.
http://support.apple.com/manuals/
SOURCE: at&t sierra error code 33
Try a reset, if that doesn't work check your wi-fi setting. If all else fails goto an apple store
SOURCE: Unable to access some apps installed on my iPad because no icon shows up on the iPad for these apps
When you exceed your allowed pages for apps,they will still install,but app cannot be created for lack of pages.You can get more room by grouping similar apps into 1 folder to make space.You can also use search function to fill any app installed.Scroll all pages to right until keyboard appears,then type name of app,it will appear in dropdown list.
Please Rate
SOURCE: Is there an adobe flash player App for The iPad?
No, there is not. And until Apple changes their policy on Flash, there never will be.
SOURCE: How do i change the battery on a ipad generation 3
You have to remove the digitizer with a heat gun then remove the LCD disconnect all ribbon cables from mainboard remove mainboard to disconnect the three batteries.
