Keep very few app in it, it will be very low capacity and downloading apps is because the processor is very slow, completely normal and there is no way to over lock or speed them up you get what you pay for... try Amazon fire stick refurbished they are about as much as you paid and can do casting and are fairly snappy.
SOURCE: hi i have just bpught an android touchpad but
You need to add the wireless network in which you want to access. You can do this by following these steps on the tablet:
Press "Settings" button (looks like a filing cabinet on most devices -> then select "Settings" - > then "Wireless and Network" - > then "Wi-Fi Settings" -> then mark the box next to "Wi-Fi" (this will turn on the WiFi antenna -> you will then see the available wireless networks.
SOURCE: When I go to use
Do not expose the <a href="http://www.laptopsbatterysupplier.com/4200mah-replacement-laptop-battery-for-a1280-p-2055.html?cPath=9_2163">apple A1280 battery</a> to high heat or freezing temperatures. Do not leave your <a href="http://www.laptopsbatterysupplier.com/4600mah-replacement-laptop-battery-for-a1281-p-2061.html?cPath=9_2202">apple A1281 battery</a>in your car in the summer. Hot <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps8-c-32_2062.html">Sony BPS8 battery</a> discharge very quickly, and cold ones can't create as much power. 6. Fully charge new <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps9-c-32_2063.html">Sony BPS9 battery</a> packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity. 7. For laptops that work as Desktop Replacement, the <a href="http://www.laptopsbatterysupplier.com/toshiba-laptop-battery-pa3534u1bas-c-447_1843.html">Toshiba PA3534U-1BAS battery</a> should be re -installed every 3-4 weeks and allowed to fully discharge. 8. Leaving the <a href=" http://www.laptopsbatterysupplier.com/4400mah-replacement-laptop-battery-for-gateway-nv52-p-1904.html?cPath=35_2094">Gateway Nv52 battery</a> in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
SOURCE: my i-pad2 will not show the programmes on bbc i-player
I would try the solution by Tim Spracklen at http://www.ipadforums.net/ipad-help/19876-bbc-iplayer-cant-stream-tv-programmes.html it may help you
SOURCE: How do I add wi-fi, verizon, at&t etc. to my amazon fire?
go to settings and search for wifi
Testimonial: "Thank you"
