Sheryl Sexton Posted on Aug 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How tall in feet and inches are 75cc? - In Office Equipment & Supplies
Jason
Level 2:
  • Expert 218 Answers
  • Posted on Aug 01, 2017
Jason
Expert
Level 2:
Answers
218
Questions
Helped
133687
Points
520
75 cm is 2 feet, 5.5 inches. cc is cubic centimeters and a measure of volume, not length.
1 Related Answer
  • 102366 Answers
  • Posted on Nov 14, 2016
SOURCE: An apple tree that is 8 feet tall casts a shadow 6 feet long. If a nearby slide is 16 feet tall, how long will the slide's shadow be?
12 feet.
If this is homework, be sure to show your work.
Testimonial: ": )"
2answers
51 inches tall and 12 inches wide. What is that in linear ft.
A total of 63 linear inches is 5 ft 3 in, or 5.25 linear ft.
What is 19" in linear inches
19" . Linear is length.
Linear feet (often called Lineal feet) are the same as regular feet. No conversion is necessary. If something is 6 linear feet tall, it is 6 feet tall. It should be noted, that the correct term is Linear, since Lineal refers to a line of ancestry, not to length.
Applies to inches also.
How do I calculate square feet of a room for wallpaper
Measure the length and width of each wall, and then add up the resulting answers. So, if a wall is 9' tall and 12' wide, it is 108 sq feet. If another wall is 9' tall and 11' wide, it is 99 square feet. Your total would now be 99 + 108 or 207 square feet.
If you are doing it in feet and inches, you have to covert the inches to feet by dividing them by 12, since there are 12' in a foot. So with 3", divide 3 by 12 and get 0.25.
What is the cu ft of Model FRT21IL4FW3 Freezer space?
Easiest solution is to measure the inside dimensions in inches, tall, width and depth. Then multiply the three dimensions t x w x d = cubic inches. To get cubic feet then divide the above answer by 1728 and the result is cubic feet..
For instance if the fridge is 60 inches tall x 24 inches wide x 18 inches deep; the answer is 60 x 24 x 18 = 25,929 cubic inches... 25,920 divided by 1728 = 15 cubic feet.
3answers
What is the average weight for 5 foot 7 inches?
Female Ideal Weight - Above Average Height The average height of a woman in the US is 5-foot-4. When considering the weight and height ratio, a 5-foot-5 woman should weigh between 113 and 138, 5-foot-6 between 117 and 143 and 5-foot-7 between 122 and 149. The weight and height ratios continue to increase at approximately 4.5 pounds at the low end and 5.5 pounds at the high end of the range, per inch of height. A 6-foot-tall woman's ideal weight range is 144 to 176 pounds and a 7-foot-tall woman's range is 198 to 242 pounds. Male Ideal Weight -- Under 6 Feet Tall Men have an ideal weight range similar to that of women, but their weights are higher per inch. A man who is 5 feet 11 inches tall has an ideal weight range of 155 to 189 pounds, which is significantly higher than the 140- to 171-pound range for women. Men under 6 feet tall can determine their ideal weight without consulting a height-to-weight ratio table by starting at 5-foot-11 and a weight of 155 to 189 pounds. Simply subtract 5 to 6 pounds per inch from the low of 155 pounds, and 6 to 7 pounds per inch from the high of 189 pounds. Thus, a 5-foot-5 man has a range of 122 to 150 pounds and a 5-foot-tall man has an ideal weight range between 95 and 117 pounds. Are There Ideal Weight and Height Ratios LIVESTRONG COM
2answers
What is the size of a water-polo goal?
they should be about 10 feet wide and 3 feet tall if they sit on the deck of the pool but if its in the water it should be 10 feet wide and 3 feet and a couple of inches tall depending on how heavy it is because the goal will sink in the water
Feb 06, 2013 • Water Sport
Top In Office Equipment & Supplies Experts
Paul Carew
vince
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
