SOURCE: evinrude outboard motor starter rope
most likly is missing a washer,has been reassembled incorrectly.take apart and check
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
SOURCE: Need online repair manual for evinrude 50hp outboard
how can I adjust the shifting linkage on my 50hp evinrude. I have the cable adjusted all the way out but it will not go into reverse
SOURCE: i have no spark on 1989 7.5 evinrude outboard motor
1973 to 1990 johnson evinrude outboard 2hp to 40hp 2 4 stroke cycle workshop service repair pdf manual/
http://www.repair-guidebook.com/1973-to-1990-johnson-evinrude-outboard-2hp-to-40hp-2-4-stroke-cycle-workshop-service-repair-pdf-manual/
