There is power And starter is engaging
Does it turn over if you jump it?
If the engine isn't turning over, how can you be sure the starter is engaging? If you're just hearing a click, the starter solenoid is probably working, but may not be completing the circuit through the electrical contacts in the solenoid which activate the starter.
If the starter is actually engaging, and if the battery has proper power, but the engine is not turning over, you have a locked up engine - mechanical issues (or hydraulic lock if there is fluid in one or more combustion chamber). Try turning the engine with a socket and breaker bar on the front crankshaft pulley.
SOURCE: 1995 dodge 1500 4x4 v-8 4x4 will not engage in
hope you can help. I have a 97 Dodge 1500 4x4 with a 5.2 litre and auto trans. After shifting to 4x4 high when you move there is a clicking sound form left front axel
SOURCE: WE HAVE A DODGE 4X4 1500 YEAR 2000 TURN
There is a service bulletin that I believe might take care of your problem.The bulletin number is 08-01-00 revision A.the problem is the starter relay fuse being blown.Check the fuse in the power distribution center.It is fuse D.If it is blown then you will have to replace the fuse and install the relay harness.Part number is 05019015AA.This is a Dodge part number and you will have to get it from the dealership.Hope this helps.Good luck.
SOURCE: Have 94 ram 1500 replaced starter and
are you sure you got the wires back on tight? Also it sounds like the bendex is not kicking out like it is supose to.....Did you change the starter cylenoied?
even some new starters are bad, it doesent happen much but it does happen. You might even take the starter back out and run Jumper cables to the starter. See if the bendex will kick out and stay out untial you diconect the starter......Sorry for your run of bad luck and I hope this is of some help.
SOURCE: won't start
If you have a spare key try that, if you have a security light on and flashing in the dash you have a fault with the anti theft system and that must be repaired to get the system working again.
SOURCE: 05 dodge magnum
What are you boosting the fuse box for,? Are you trying to blow the vehicle up? Where did you learn to boost a car? The car that your useing to boost the car hook up one cable at a time to the batterys of both vehicles The car your useing for boosting hook up the ground to the battery first ,Then on the car that your boosting hook the ground cable to a the engine some where , To ground it, Not buy the belts or moving parts , Then hook up the positive to the postive terminal of battery in the car you are useing to boost the other car ,Hook up positive cable to positive terminal on car that you are trying to get started, If you don,t no what your doing get help from some body that has done it before, One wrong move you can (Screw) Up the computer in the car, End you might of done that (Allready)
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://www.howtorepairguide.com
These will help.
Thanks.
It
From
Won't Start?
These will help.
Thanks.
