The red light keeps blinking. it is supposed to remain red constant and then turn to green when charging is complete.
Simple solution ! just wire a 9V battery postive to positive and negative to negative ( be careful not to interchange them ). hold it together for 30 seconds ! done !
All this does is give the battery diode inside, a boost ! so that its connectors are activated and Voila ! it works camera's now charging !
Sweet! Worked... thanks
Sweet, worked!
Yep, worked for me as well. Thanks!
I had the same problem. Called Casio customer service and was told that this has been a problem with a lot of the batteries. They are sending me a new battery for free. The number is 1-800-435-7732. They gave me no argument at all. Call 'em up!!
The reason that this is happening to because the connector cord has been placed into the charging station upside down. Unplug it and flip it over so that the 125V reading is towards the bottom and the "well shin" reading is faced upwards (facing the side of the charger where the battery and light appear.)
this should solve all your problems; I think the blinking red light is just an alert to let you know that the connection is wrong.
If you can’t get the manufacturer to fix it or send you the parts you may want to try and fix it yourself. I found a guy in South Carolina who sells good used parts and will give you some suggestions on how to do it yourself. I bought a LCD from him for $39.00, fixed it myself and it works great. I think his email is [email protected]
04/23/12 Just called CS at Casio, sent to repair then to parts. After being told I would have to buy new battery the parts person told me they could send me one as a courtesy! The cost would have been $46.00 so make those calls. They must know something is wrong.
If you call casio tech support, tell them your camera is less than a year old. They will not give you a battery if you tell them that your camera is more than a year old. FYI.
Blord2 got it right. Call the number posted..advised of problem, no fuss or questions asked-- they advised this is a problem they have been having, and are sending me a brand new battery for free!!! -- said it should arrive in two to three business days.
I had the same problem and I called the number that is posted on this forum, which is casio technical support. They said it is a known problem and are sending me a free battery.
Hello, I have a Casio Digital Camera model Exilim EX-Z70 come to use it will not switch on, took out battery to charge up, red light on charger keeps blinking, left to charge for over two hours, placed battery back in camera, still will not work.
SOURCE: I am not able to charge the Exilim battery.
Same, I'm having this problem at the moment. and when you purchased this, they should give you a notice to NOT return it back to the retailer to any technical or repairing support. I haven't really called them yet, since they are closed already. But if anybody is wondering what the number is, here it is:
Technical Support call: 1-800-435-7732
9AM to 8PM EST (Mon-Fri)
9AM to 5PM EST (SAT-SUN)
Repair issues call: 1-800-706-2534
9AM-5PM EST (MON-friday)
hope that helps.
When I keep the battery for charging the red light keeps blinking. I bought the camera just 4 months ago. So the battery is new. It has not been used much. So, what is the solution? I have not done anything to solve the problem.
I have the same problem...any solution?
Same problem here. The first time it happened I took the battery out of the charger and put it back in a few times until the red light was burning steady. Now it just blinks.
I do have the same problem... the batery keeps blinking yet never charges, so my camera is USELESS!!!
My charger blinks a red light also, the battery is a year old and been re-charged 5/6 times.
Same problem. The camera is only months old and charged 3 times. Is it the battery or the charger?
Same problem. Charged battery twice now just blinks when I try to charge and the camera won't work.
I called the 800 number like the last guy said and it worked! Casio is mailing me a new battery! Thanks so for the help!
same here, camera was working fine then one day, blinks red won't charge. what do I do???
yes i got the same problem..even i bought a new battery and charge it to full power, the battery is dead again after a week (i only used the camera for 1 day, about 120 photos)...the camera used up the battery when it is turned off???
Yeah I have the same problem. This camera is almost brand new. So i called the technical support and they are sending a new battery free of charge.
Casio Exilim EX-Z750 digital camera battery charger flashes red, even after I bought a new battery.
I fully recharged my camera and the light turned green. then i left the camera in its case for 1 week witout using it...the battery is dead again!!!!
its
My battery is dead, when I put it into the charger it just continues to blink. Not the typical soild, it has done this before but fixed itself somehow.
How can we fix this?
My zte savvy shut off while charged and when i try to turn it on blinks red in charging light y and will it work again
