Lights indicate the room temp on the left but do not know what the numbers areon the right side.
SOURCE: 1999 m3 light indicator light--what does it mean
does the one look something like this? IIIOIII or (((O)))
this is the brake wear indicator saying that you need brake pads somewhere on the car (front or rear).
the other sounds like you either have the traction control (its a button with either DSC or ASC written on it) turned off or its showing you that it is off because you need need brake pads.
SOURCE: I live in an apartment with central air
Yes, Set the right side to 74 and you should feel cool air from vent Give it 15-30 minutes and chk to see if left side drops. If it has a preset at a certain time it will default to the preset if its in that time period and is shut off. Make sure it is set on cool. 84 is hi and is normally set there by managers to cut costs.
SOURCE: Amana Model SZD25NL is not cooling at all, neither
compresor fan working? if it is not you need to consider the compressor starter need to be replace
SOURCE: the tv dont want turn on and in the right side of
You can get one here for your TV Click Here .....
Here's your part number for the lamp: TY-LA1000
http://tvtechwork.webs.com/
