I have no idea if the cellphone is CDMA or GSM, very little info.
Look for Consumer Cellular APN settings in the internet.
Check that your device APN is set exactly as Consumer Cellular. If not, set it up. That should fix your internet problem.
To get to the APN settings, go to settings, more, cellular networks, access point names.
SOURCE: Cannot connect using LG internet cube software
I had the same problem but now i have found the solution for it. Its not the software its the phone. Go to your Phone Settings hit Connectivity and then Usb Connection select Data Service and now connect your phone to the pc and select connect in Mobilesync and it should work. After you are done using MOBILE SYNC you can simple go in settings once again and choose mass storage for any downloads!!!
SOURCE: LG KG800
For manual..
http://www.austarmobile.com.au/userguides/LG_KG800.pdf
for Drivers..
http://chocolate.lgmobile.com
SOURCE: how to connect to internet using my LG KP 320 mobile phone
recently i bought a lg mobile but it was not provided any drivers or pc suites.all i want is how to connect internet.if i need to download any drivers ,i want to know where.
SOURCE: bluetooth and lg phone randomly connect and disconnect
you can try removing the device and repairing it.
