SOURCE: wanna install a cherry tiggo 2.0 sqr484 cambelt after the campulleys was removed by engineering
Bill Hackett provided this answer back in January 2014 for another Chery Tiggo owner.
SOURCE: need timing belt mark diagram for 95 corolla 4afe
malibluert: YOUR IN LUCK! This series engine is simple and the references aren't hard to find. READY???????
IF you are just trying to reset the belt at the top and have not remover the crank pulley, bring the crank around to Top dead center on the # 1 cylinder,. It will read Zero degrees on the timing mark scale.
Up top, look at the cam gear closely You will see that there are 5 spokes which support the actual gear. Look closer and you will see that one of these spokes has a small hole in it about 3/4th of the way towards the outside of the gear. Position the gear to where that hole is at 12:00 PM. NOW, if you look thorough the hole, you should should see a small notch that the hole should be centered on. If not, move the gear until you can look through the hole and the notch falls dead center. At that point in time, you have the crank ant camshaft in perfect time with each other.
When you put the belt on, make sure that the side which is slack is the tensioner side. You should be able to slip the belt on, matching the teeth with the teeth on the gears to where one side is fairly tight and you can not roll the cam counter clockwise.
IF you are replacing the belt, you have the crank pulley off and you position the woodruff key straight up at 12:00 PM and the procedures are all the same other than that. when you set the tension. A good rule of thumb is to find the longest span of belt, and with your thumb and forefinger twist the belt. if it twists to 45 degrees toward the block, it's perfect. Any more or less, needs to be reset.
I hope my answer suffices. A picture wouldn't be any more clear.
Let me know how you did.
NOTE: This engine does NOT bend valves when a timing belt fails.
