SOURCE: Ge top freezer refrigerator ice maker problems
Ge refrigerator, ice maker seems to work but ice is not dispensed. If I open drawer and move ice towards the front it will dispense one or two pieces of ice.
SOURCE: Kenmore Bottom Freezer 596.71103101 Ice maker not working right
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
SOURCE: amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.
Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
SOURCE: fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
