But, yet in the operator manual it says it should be a microscopic dimension of 0.65mm. Yeah-as in just over One-Half of One MILLIMETER!! That Can't truly be the case, can it?
Compound microscopes can be
found in most biology and science classrooms. They are electrically
operated and use light to enhance the image of a cell. They will have
multiple lenses for viewing.
Dissecting Microscope
Dissecting microscopes are also
known as stereo microscopes. They have low magnification and are also
light powered. These microscopes can view objects larger than what a
compound microscope is able to handle, in three dimensions.
SEM
A Scanning Electron Microscope
uses electrons instead of light to create an image. These microscopes
produce three-dimensional images with high resolution and magnification.
They also have a larger depth of focus.
TEM
Transmission Electron
Microscopes use electrons instead of light to create an image. The
material prepared must be very thin. The beams of electrons that pass
through it give the viewer high magnification and resolution. These give
two-dimensional images.
It is most likely your dimmer control switch. It is a variable resistor that controls how much voltage is going to your bulb. You will want to contact a local microscope repair company that services Olympus microscope in order to either get it fixed, or to get the part.
You don't need a specific microscope manual for that microscope, any old microscopy guide will do as at that level, all microscopes work pretty much the same way. Enjoy.
I found out that Tasco microscopes have been discontinued quite some time ago. A Company called Bushnell 1-800 423-3537 who gave me the number of ABO 305-859-2010 Tasco microscope 750X # 60750-0 call after 3pm. They do not have my manual but can answer questions or send a similar manual. I have to call back stiil hope this helps. Zoom
