Question about Electronics - Others
I will to clear error code e.op from keb f5 - Electronics - Others
4 Suggested Answers
6ya staff
SOURCE:
mntech1
  • 120 Answers
SOURCE: Hi i m using keb
These operations are clearly defined in the manual what was sent with the inverter originally. If you no longer have the manual, contact the company that you purchased the controller from and request a replacement manual.
Posted on Feb 21, 2014
mntech1
  • 120 Answers
SOURCE: F5 KEB inverter nop problem
If using bus communications (Can, ProFi, Mod, ext), there may be a communications command (Software signal) that is not being provided. Hardware and software enable signal required to obtain LS.
Possible that the terminal on the control card is bad due to miss connection or signals outside of the rated value.
Posted on Apr 01, 2014
mntech1
  • 120 Answers
SOURCE: Fcon in keb f5
Forward CONtinues
System is at the commanded speed in the forward direction.
What Error COM KEB mean ????i have F5 version
The KEB inverter does not have a "COM" error.
Where is this error being displayed?
Check your inverter baud rate, inverter address, communications cables and device that is being used to communicate.
Feb 12, 2014 | Inverter KEB COMBIVERT F5
Tip
KEB COMBIVERT F5 help
When ever you have a questions about a KEB Combivert inverter, it is best to provide as much information as possible. At a minimum provide the following:
Part# or art-nr
Serial # or ser-nr
Fault codes
Type of machine
Machine manufacture
Problem description
KEB manufactures many different types of F5 inverters and each type has different hardware, software and functionality. With the above information it is easier to provide a better solution to the problem.
on Nov 27, 2013 | Inverter KEB COMBIVERT F5
Keb inverter f5 error e.pu
General powericon1.png stage failure.
Most likely will need to replace the power stage or inverter.
Oct 03, 2013 | Inverter KEB COMBIVERT F5
General fault 142error
This does not appear to be a KEB error code. If this code is on on your HMI, contact the machine manufacture to determine what this error means.
Sep 25, 2013 | Inverter KEB COMBIVERT F5
General fault 142
The does not appear to be a KEB error code.
About keb f5 inverter
you can download the keb f5 manual from this site
http://www.keb.de/en/service-downloads/downloads.html
Jun 26, 2013 | Inverter KEB COMBIVERT F5
KEB 07 F5 Error code E. Puch what will cause this error and how do i clear it
E.puch means that at power up the control card did recognized the power stage as different than last time it powered up.
This is normal when the control card is changed. If the control card has not been changed, there is a problem between the power stage and the control card.
Initialize the value at sy.03 to reset the error.
Apr 25, 2013 | Inverter KEB COMBIVERT F5
I use Keb F5 on lift, there is no error message but lift does not move
If there is no error, the inverter is doing what it is be commanded to do.
Check your control signals to verify that they are providing the proper signals to the inverter.
KEB sells inverters to many different type of lift manufactures. The lift manufactures themselves have good tech support for their equipment.
Apr 03, 2013 | Inverter KEB COMBIVERT F5
F5 keb inverter problem
i have a prblem in the F5 keb combivert it's show Error
E.OC & E.puci & E.Puch could you please advice us with the proper solution
thanks
Mar 10, 2010 | Inverter KEB COMBIVERT F5
Electronics - Others Logo
569 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
