SOURCE: Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
SOURCE: Did'nt find what I was looking for. I need a user
When going through my paperwork I found the manual I was looking for in english. Many thanks for your help. T. Maddocks.
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
SOURCE: I need instruction manual for Bosch Maxx WFL 2451
Here is a manual.
If it's not he correct on go to the below link and search with the model number WFL2451
Link
