Question about Sharp Refrigerators
Sharp SJ-F624ST 4 door fridge/freezer. Moved house . When switched on "door open alarm " sounds continuous. fridge / freezer not working . all doors close fully. What could be the problem ?
    New Friend:
Euva no tecnico
Posted on Jun 27, 2017
6ya staff
SOURCE:
Hye..recently i just notice my sharp plasmacluster model sj-pt491m-bk the chiller is not working. Not cold as normal. The above freezer working normally. Plz advise
Open Freezer Door Press Door Switch and checked Freezer Fan is working or not.
If fan is working then problem in Ref compartment. If not working then replaced Fan.
In Ref Compartment checked all duct clod air is coming or not.
If not coming then Damper is defective.
Dec 25, 2015 | Sharp Refrigerators
How to disconnect or isolate door open alarm for fridge & freezer
Disconnect the door switch, this will stop alarm but light won't work
Dec 20, 2015 | Refrigerators
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
My sharp freezer model SJ-229S-SL , UPPER IS WELL BUT BOTTOM NO COLD
Checked Damper in Ref its working or not. You can checked open Ref door press Door Switch and hold your hand near chiller tray Duct
Dec 27, 2013 | Sharp Refrigerators
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
Why is Fridge not cooling well?
The part number you need is going to be WR09X10050. This is for the damper assembly, but while you are at it change out part number WR55X10150. this is the part that controls the damper and more than likely if one fails the other will be soon to follow
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Hotpoint Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
Whirlpool fridge alarm sounds when opening the door most times.
Speedysgarag, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Speedysgarag), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool ARC4030 Stainless Steel Top...
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator doesn't stay on.
sounds like when you moved it you created an air lock, when moving fridges etc. should always leave for 24 hrs to settle before plugging in.... , no guarantee but try laying it down and leaving overnight then stand it up again and leave for at least 24 hrs for the refrigerant to try and sort itself out. UNPLUGGED from mains of course... good luck
May 02, 2017 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
497 people viewed this question
Top Sharp Refrigerators Experts
geob91
Elie Balas
Vernon Taylor
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
