SOURCE: My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
SOURCE: can i dive with this watch?
You definetely CAN NOT dive with this watch. It is good for swimming and snorkeling only. Real divers watches withstand at least 200 meters of depths and are specialy designed for it.
One of the best affordable divers watch manufacturers novadays is Seiko. Check Seiko website and learn about divers watches and all the features they have. List of waterproof markings and explanations are also available.
SOURCE: luminox bezel
Grab the knurled edge of the bezel and turn counter clockwise. It only moves in one direction- to the left, counter clockwise.
SOURCE: Replace mineral crystal in Zodiac Sea Dragon ZO-2201
Its better you bring your watch to a service center ,Because equipped of all the tools.
Hope it may helps;
SOURCE: 3903 Blue Faced Seal Dive watch Bezel
best bet is to contact luminox...i had to do it for mine. Even if it was a purchase from a third party, they may take care of it for free...
