Drills Logo
Posted on Jun 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ryobi Li-ion strimmer
Battery seems OK, charging properly but somewhere in the circuitry of the strimmer there is an intermittent open circuit and the head stops and starts. Trigger switch is OK, connection contacts seem OK. Is there is speed sensor that could be causing trouble?
Bill Boyd
Level 3:
Top Expert:
  • Ryobi Master 53,816 Answers
  • Posted on Jun 16, 2017
Bill Boyd
Ryobi Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11931854
Points
172802
Check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
P107 red light on green light flashing 2 batteries neither will charge ryobi 18 volt lithium charger working could both batteries go bad at same time
Replacement for Ryobi P107 Power Tool Battery
  • Type: Li-ion
  • Volt: 18V
  • Capacity: 6000mAh
  • Color: Black
  • Weight: 898g
  • Dimension: 135.70 x 76.00 x 107.30mm
http://www.drill-battery.net.au/buybatteries.php/ryobi_P107_power+tool+battery.html
  • Type: Li-ion
  • Volt: 18V
  • Capacity: 6000mAh
  • Color: Black
  • Weight: 898g
Can I buy a battery charger for a ozito drill
hi Terry.
you could try homebase.or ebay will have them.
or this link should show you where you can buy them.
battery charger for ozito drill Google Search
Dec 02, 2017 • Drills
I need the XLR pinout for my Air Hawk portable wheelchair. The charger fell out of the wheelchair pocket on a flight, I need to charge the 24 V battery Li-Ion so I can make it back home with power.
is this ref any use ?
XLR Style Charging Cable for wheel chairs scooters and electric bicycles
be careful over what charger you use as Li-ion batteries must not be overcharged. most have a sensor that detects the voltage and stops charging when the battery is fully charged. This circuitry is inside the charger, not the pin.
Ryobi P110 chargers internal transformer is burnt out? what is the rating on it and where can i find it?
Unless you are a bit clever with electronics, better off buying a new charger than trying to fix the internal circuit on it. here is some links to info ive found.
a new Ryobi 18v li charger will charge your nicad battery but a nicad charger will not charge li-ion battery.
http://powertool.manualsonline.com/manuals/mfg/ryobi/p110.html?p=1
http://manuals.ryobitools.com/documents/2101
2answers
I currently live in Europe and have a Ryobi CHP-1802 drill with an 18 volt Li-Ion battery. The charger is a Ryobi BCL-1800 220 Volt, 50 Hz. I am moving back to the United States and want to keep thi
After looking at the manual for your charger, it looks like most of the Ryobi chargers like the P113, P114, P117, P118 will charge your battery. The connector on the battery looks the same as the P103 and P104 used here in the U.S.
How to CHARGE CORDLESS DRILL
First, you should know your battery is a Ni-CD / NI-Mh or Li-ion battery. If it is a Ni-CD / NI-Mh battery, please fully discharged and fully charged it to prevent "Memory effect".
If it is a Li-ion battery, please charge it before you use it.
Please keep in mind that, please fully charge a battery when you store it. And, charge it again every two months.
If your old battery is dead, you can replace it with a new one. Ryobi Power Tool Battery
Oct 05, 2014 • Drills
Are all the Lithium batteries working like this. Mine work for a short time then stop dead. Wait a while then they will work again. Really a pain when you are working trying to do somthing and have to run...
I use the Ryobi Li-Ion tools the L-I batteries will cut off when they get to a low charge level this is to protect the batteries Li-Ion batteries life span is shortened when fullt discharged so when the tool suddenly stops put the battery on charge,also if the battery has a charge indicator light for a more accurite idea of the charge (green is charged,red discharged) hold the test button on then run the tool the light may go from green to red if it does that shows the the charge is about depleted if the light stays green you have a little run time left.
1helpful
2answers
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
13helpful
2answers
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Battery charges but is dead
The battery isn't any good. The charger is just going through it's regular steps. (I know how it is. I just bought two Ryobi 18 volt batteries for my Ryobi cordless drill, reciprocating saw, flashlight,
trim circular saw, combo set. $60 for two batteries)
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
