I am having oil pressure issues with my 2006 Honda Shadow Sabre 1100 sometimes it will be fine then it will not have oil pressure any answers
SOURCE: how to change sparkplugs on honda shadow motorcycle
VT1100 has two spark plugs per cylinder, the sparkplug caps are snap-ons so they're fairly easy to remove. You need a spark plug socket wrench to remove and replace the spark plugs.
SOURCE: what is the best oil for my 2005 honda shadow
Honda Oil ... available at your Honda Dealer. find him at http://hrca.honda.com/
SOURCE: I cant find my oil
The oil pressure switch is located on the main crankcase/block on the bottom left side next to the neutral switch. The sender on the left/front is the neutral switch and the sender on the right is the oil pressure switch. They are probably hard to see because the left exhaust pipe is in the way.
