What software program do I need to enable etching a label directly to a lightscribe rewrighter onto a lighscribe disc. I have the Disc, need the software program
The LightScribe feature of DVD burners with this capability requires that you are using burner software that has this function. Verify that the software you are using is lightscribe compatible. The software that comes with this drive(Nero) should be lightscribe compatible. After you burn the disc you do need to fip the disc over and the re-insert into the drive so that a label can be etched into the disc. The lightscribe discs look identical on both sides so only one side you can burn info and the other side is for the label so make sure that it is inserted on the right side for each process. If you put the disc in on the wrong side the initial data burn will not work. Also sometimes burners will have issues with certain brands of discs so you may also want to try a different brand and see if that helps. And another thing that you can try is updating the drive to the latest firmware. The firmware is to the drive kind of like what Windows is to your PC. Sometimes updating this file will fix problems like this. Here is a link to the firmware of your model. http://support.asus.com/download/download.aspx?SLanguage=en-us
You can download the file and run it to update your firmware. Caution: Before running the firmware make sure it is the correct file for your drive! There are a couple of variations to your model number and this one might not be the correct one. If you install the wrong file you could damage your drive inoperable or defeat some of it's features. I hope this information is of help with your problem and thanks for using FixYa.
You need special absorbent coating on the printable DVD's if they are suitable for that. Are you sure you can print on the sort you have usually they are all white. It also must actually say suitable for PC printed labels etc too.
you need to launch the lightscribe software, insert the disk upside down (opposite to what we use when burning data into disk), select the image in the software and start burning.
Printing Directly onto a CD or DVD in Roxio Express Labeler
Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
Click
Start
, click
All Programs
, click
Roxio
, and then click
Roxio Express Labeler v3
Click
Disk Label
, then click
Options
Figure 1: Options1 - Options button
The Options screen appears.
Figure 2: Options screen
Make sure that
LightScribe 12cm Disc
is selected from the
Disc Label
menu, then click
OK
to return to the Roxio Express Labeler window.
Click
Disc Titles
, type the title and subtitle for the CD or DVD, and then click
OK
Figure 3: Disc Title option1 - Disc Titles buttonFigure 4: Edit Disc Title screen
Click
Background
, then click
Import Background
to use an image on the computer as the background on the CD or DVD. Click
OK
Figure 5: Background option1 - Background button
Insert
a LightScribe CD or DVD into the LightScribe drive of the product. Make
sure that the label side of the disc is facing down.
In the Roxio Express Labeler window, click
Print
. The LightScribe label is printed on the CD or DVD.
Figure 6: Print1 - Print button
There should be a lightscribe program that came with the DVD drive. just flip the DVD over (make sure it can do lightscribe) and run the program that came with it and choose an image and burn it.
You can get colored blank discs, but the Lightscribe only "prints" in shades of black. You will need to get Lightscribe compatible discs, which are just like "normal" cd's / dvd's with the exception of having a special coating on the one side.
You can visit Lightscribe's website for complete tutorials.
