Bad connections on the power supply board or caps you can get some free spray and when it goes out freezer components in the power supply when it comes back on you'll know which components bad
SOURCE: RCA..PTV..P60924..CTC195M..NO START UP.
High failure parts = Flyback.....# 239111 and HO transistor =
237470 ....DO NOT USE cheap generic.................T.
replace both at same time......................T.
SOURCE: HP printer AC power adaptor 0950-4399
I just get one from www.order-bulk.com my print is working now
SOURCE: I bought a NU-TEC DVD 318 I want to make it region free
1. Turn on the DVD player, and DO NOT have a disc in the unit.
2. Press the “setup” button on the remote, and then press "1389" on the
remote.
3. You will then see an information screen, with Region Code: 4
displayed.
4. Use the Up and Down keys on your remote to change the Region Code to
0, and then press the Enter key on your remote to confirm the change.
5. Press the Setup button to exit the setting.
Your unit should now be region free.
SOURCE: Does anyone know where to get NU-TEC LCD TV Parts
For all inquiries Nutec LCD TV's in Australia below are the details.
Contact Yale Prima PTY LTD
Ph: 1300366155
Between 9am & 5pm AEST (Australian Eastern Standard Time)
Regards
Geoff
SOURCE: I would like the remote control code for a Nu Tec
I don't know if this helps you,but it may help someone, if you set the lock on this model and forget the four digit code enter 8034 on your remote doing this will switch the tv off, turn your tv back on, after your tv is on you will see the first time installation guide, select your language retune your tv, the code will reset back to 0000. In the book it says this password cannot be reset, it also says the first time(and only the first time) you turn on your tv set, you see an installation guide. how wrong they are, hope this helps.
Can you plz tell me how to get circuit diagram
