The display on my Novotronic w310 shows 'blocked drain'. What do I do?
    Top Expert:
  • Washing Mach... Master
  • 30,696 Answers
Check there is no blockage.
Posted on Jun 04, 2017
6ya staff
SOURCE:
Miele Novotronic w310 washing machine - won't spin and flash 'rinse' on the display?
Did you try to set the temperature to the minimum?
Maybe the heating element is faulty....
Nov 30, 2015 | Miele Washing Machines
The intake light comes on and the machine will not go thru cycle, it just hums.Water does not drain.
its obvious the drain pumps blocked, rempty machine, remove drain plug, wire mesh scoop water in middle, then take off the plastic cover with a steel like wire on it, clear out the **** blocking the pump, assemble then should be ok.
Jun 14, 2011 | Miele 23 in. Novotronic G841 Built-In...
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Water leaking
deafenatly sounds like a blockage or remove soap dispensor and check that there is no damage below it
ie a crack in the plastic allowing water to escape
Jan 16, 2010 | Miele Novotronic W1918A Front Load Washer
How do I check the filter on a Meile Novotronic W310
the filter is on the bottom left side in the front panel
also the drain pump is there.
Dec 24, 2009 | Miele W310 Front Load Washer
Softener does not go into machine , still there after washing. Not blocked in tray as cleaned thoroughly MIELE W310
Water jets in roof of soap container are blocked and / or conditioner syphon assy blocked . clean all and retry
Nov 03, 2009 | Miele W310 Front Load Washer
Red light flashing
red light is check drain?
Clogged by something.
Could be a coin.
Use to have large coin when i was young and forgot remove from my jeans. So mum made me repair that every time. In that case filter clean, but coin bloking filter inlet.
Not necesarily coin in your case.
never buy these deals over Ebay my advice.
If you have the machine already then this is first to look for.
Nov 16, 2008 | Miele W310 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
