SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
SOURCE: Hilti DD130 Core Drill gearbox Lubrication
Hi
220ml of synthetic 68 gear oil.
Hope this helps
Testimonial: "Appreciate the advice Wysepaul Can I ask from where this information is sourced? It makes sense that a synthetic oil is used. Any particular brand? Ta"
SOURCE: will a Hilti TE 17 to drill 1" holes in sandstone?
The TE 17 is at least 29 years old. It will do up to an inch. However there are no parts available for this tool. Also be carefull if it has a black fill cap on top of the gear housing then it does not have a safety clutch. If it has a red one then it does have a clutch.
SOURCE: drills but dont hammer te 74
Hilti no longer carries parts for the 74. However most of the TE75 parts will interchange with the 74
SOURCE: Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
