Olevia LT27HVX 27 in. LCD Television Logo
Posted on Jul 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 27 " Olevia LCD - TV. It
I have a 27 " Olevia LCD - TV. It screeched then went to blue screen. Turned back on all fine tuning is gone and locked. I went to default that doesn't change the fine tune lock. Any help ? [email protected]
Anonymous
Level 3:
  • Master 636 Answers
  • Posted on Jul 25, 2009
Anonymous
Master
Level 3:
Answers
636
Questions
Helped
264413
Points
2016
If it hot were you live t.v;s don't like heat above 35 degrees celsius
2helpful
3helpful
I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
1helpful
2answers
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
1helpful
My LCD screen went of but there still sounds coming out
you have to check the back light off your lcd replace the inverter or capacitor in the power module
My Olevia LT37HVS 37' was working fine all day and turned to black screen.
It is either the fluorescent backlight source for the LCD panel or its associated power supply failing.
2answers
Olevia T.V problen
Try selecting a different input, or checking the device which you are receiving the signal from. A blue screen typically indicates that there is no signal.
Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
BLUE SCREEN only when power is turned on
How do I set up and program my olevia hd tv. bought without manual
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
