I have a beeman tempest and every time I cocked it it would not shoot. The pellet seem to get stuck in the barrel. I do hear a pop but the pellet is stuck inside the barrel. Looks like there is not enough power to fire the pellet. Should I replace the mainspring?
SOURCE: Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
SOURCE: beeman air rifle wont latch when cocking
you have a triger fault its not locking the piston back best and safest bet is a gun smith,, never play with a triger if your not good with guns,
SOURCE: My Beeman RX-1 will not lock upon cocking. I was
Check the trigger guard screws. If the trigger guard has been loosened or removed, it can effect the proper position of the safety actuating lever (the lever in front of the trigger adjustment screw), preventing a full cocking stroke.
SOURCE: when I **** the barrel to compress air it won't
If it new, it must have a warranty of some kind. Use the link below to contact customer service for help.
Crosman recommends that you take to a service center, and adds the following. >DO NOT ATTEMPT TO DISASSEMBLE IT< Your Phantom requires special tools and fixtures to repair it. Any disassembly or modification not performed by an authorized service center will void the warranty.
Crosman customer service
http://www.crosman.com/airguns/service
SOURCE: i **** the marker. screw in hpa. so far so good.
Replace all of the o-rings within the gun make sure that the striker pin is free to move. The striker pin is the one that the big striker hits, it is on the inside of the pressure tube.
