Edited text with a wild guess at the maker. Make model (what it is) in all questions please.
Category moved to John Deere Tractor.
If it was working before, there is no need to worry about the firing order as that never changes. Things to look at;
Clean and correctly gapped spark plugs,
Clean gas,
Fuel filter?
and a clean carburetor, float bowl and jets.
John Deere 3020 Engine
Engine Detail
John Deere
Firing order:
Starter volts:
Oil capacity:
9 qts 8.5 L
13 more rows
Jul. 10, 2020
This John Deere model 3020 Gas and Diesel Tractor Service Manual is a digitally enhanced reproduction of the original manufacturer-issued Shop Manual.
US$120.98 · In stock
This is a new reprint of John Deere Service Manual SM2041 for the John Deere 3000 Series Tractors shown above. It is dated June 1961. Includes 3010 & 3020.
It is almost like a 4620 powershift farm tractor trans. When reverse goes clutch packs are shot. Sorry about that. Be sure the shift linkage is moving full range top to bottom.
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
JD 400 Garden tractors were made from 1975 - 1983.
Serial Numbers
1975: 30001
1976: 55001
1977: 70001
1978: 80001
1979: 95001
1980: 120001
1981: 155001
1982: 190001
Go to this site and you may be able to track it down. John Deere 400 attachments
http://www.tractordata.com/lawn-tractors/000/0/4/41-john-deere-400-attachments.html
Be sure to read this discussion on serial numbers.
"Find the REAL serial number
There are usually a lot of different numbers on a tractor. The engine, front axle, and cab may all have their own serial numbers. Various components may have parts or casting numbers. Make sure you have actually found the tractor serial number, and not one of these other numbers."
First off, Mowerman's response was incorrect about the age of a JD 317. They were made from 1979 to 1982.
You can only get manuals either through here: http://techpubs.deere.com/deere/Default.aspx or from a dealer. They're expensive. You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
