http://www.instructables.com/id/How-to-change-the-traction-belt-on-a-John-Deere-LT/the link shows the routing and idler spring either wrong size belt -inserted wrong or broken spring idler pulley
Rex, check the drive belt,old stretched, loose, broke, fell out of position Tension er weak or seized if equipped, worn out pulleys.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Tightening the belt on John Deere L110 Tractor
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
I would need the model # of the deck and tractor, but all newer mowers use a spring to maintain constant belt tension. I can get you a diagram if you need one.
It is better to replace and not adjust the wheel drive belt, too loose and it slips, too tight and you ruin very expensive bearings YOU can not replace...Belts are cheap, bearings are very expensive!
