SOURCE: I have a fan forced
There has several reasons the fan could have stopped working:
-It is possible the fan wiring/connections have become loose or unplugged
-It is possible that the fan motor has worn out or become jammed over time due to debris
-If you recently cleaned your oven, the fan could have stopped working if it came into contact with any caustic oven cleaner.
Hope this helps.
SOURCE: I need to obtain a
Hi trendymum,
Plz specify the product mdel no. for specific manual..However plz try this link hope it works if not kindly revert:
http://www.manualsonline.com/ex/product/headline/m/Chef/d/upright%2Belectric%2Bfan-forced%2Boven%2Band%2Bcooktop/p/Select-about%2B10%2Byearsold
Thanx
SOURCE: how to fix noisy fan in chef fan forced oven
Possible fault in the bearing bushes , in the first place you can spray a WD40 or even some light oil into the fan's rotor ends where the bearings are located. If the sound reduces clean and wipe off excess oil from the shaft side. Also make sure that the fan leaf is not making the noise due to any dirt accumulation or obstruction.
