SOURCE: Age of Amana washer
Hi there Sue. Go to this Amana link and input your data. They will tell you the age.
http://amana.custhelp.com/app/answers/list
SOURCE: maytag refrigerator
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
SOURCE: I have a Haier compact refrigerator (Model:
Unplug the unit then turn the thermostat all the way on then all the way off, then slowly move from off to fully on position do you notice a spring popping sound at a certain point? Yes No? if yes turn it all the way off and wait ten minutes then plug back on, notice if the compressor comes on or not. If it does then turn the thermostat to half way on does it cool now? if yes you have the problem solved, if not you have an issue with the defrost circuit and you need tools to test it, if you have an ohm meter let me know and I will help you further. Thanks for using fix-ya
SOURCE: Haier Model HRT02WNC compact refrigerator not cool...
this model is thermoelectric and has no gas in it.
It uses a peltier junction to provide a temp differential. the fan will run constantly, and it will cool the interior to about 35 degrees F below ambient. theoretically...
